i got the 2 front bolts out, how do you remove that rear one??
alternator removal question
Alot late but may help someone else......
3.4 DOCH rear bolt removal the easy way....
I assume you've aready got the cooling ducting out of the way...
Grab yourself a long 10MM wrench.
NOT the standard lenght 10mm wrench.
Place wrench on bolt guiding it with your hand.
You should be able to see the BOX end of the wrench poking out
from the ALT.
Now, grab your self a rachett and attach the longest extenstion you can find. Half inch i think.
It just so happens that the 10mm box end of the wrench will accept the end of the extension perfectly.
Insert extention end into Box end of wrench.
Now you can lossen the rear bolt enough to finger it out the rest of the way....
Test,
