I just had a question about the differences in the cam cog assemblies for the 93 and older and 94 and newer engines.
Looking at the picture of the cog/taper seat assembly shown in this thread.. http://www.60degreev6.com/index.php?...ewtopic&t=6429 it appears that one COULD replace the bastard cog/lock ring assembly on the 93 and older engines with the newer taper lock assembly from the 94+ engines.
Has anyone tried to do so? Does anyone have the dimensions of the cog end of both style camshafts to compare? IF the dimensions are identical, swapping the lock rings for the taper seats should be possible and make changing the timing belt a ton easier.
Just a thought.
RED
Just a thought.
RED
