Couldn't I set the cams to stock settings, then pick a cam, loosen the lock bolt, put my degree wheel on the crank, and rotate the crank the desired degree's for cam settings? So what I should be setting for (96 3.4) is crank rotated 12 deg clockwise for exhaust, and 4 deg clockwise for intake. right?
Timing. WAIT A MINUTE!
PCV valve and vent tube, reroute to exhaust to dump where it belongs, on the ground. Or add breathers and let it all free.Tags: None
