got to thinking about the igniton again....
with 5mS dwell periods.... and each coil getting fired once per revolution(waste-spark)....
the EST circuit has to transition from high to low every time for a coil to charge, then discharge. if the EST line remains high for 5mS for each coil, that's 15mS per revolution... 15mS revolutions = 4,000RPM. so beyond 4000RPM, 5mS dwell periods aren't possible.
so let's look at 3mS dwell periods.
3mSec X 3 coils = 9mSec. 9mSec dwell periods = 6,666 RPM.
2.5mSec = 8,000 RPM.
so.... depending on the real-world coil saturation time, you could realisticaly lose spark energy above ~6700 RPM...
with a 4 cylinder application using the same coils, they hit 10,000 RPM at 3mS before it becomes a problem.
with a 8 cylinder application(93-99 northstar and LT5), 5,000 RPM....
then again, this is assuming that the ICM isn't doing anything differently. i read it somewhere from someone who stuck a scope on a 60V6 ICM, but supposedly, the ICM limits current to the coil to ~5 amps or so. if that weren't limited, then they could certainly charge up faster considering their primary resistance is actually really low. i think somewhere around .5 ohms when i last checked....
more assumptions would be that the ICM doesn't change the current limit based on RPM.... a lot of "what ifs".
