been fussing with this since yesterday. A friend and I replaced the 02 sensor (bank 1 2nd sensor.) Now it won't start at all. It just floods out. Remove spark plugs, dry them off, pull fuel pump fuse/crank it over until it stops pushing fuel out. Put plugs back, it'll fire but shortly after it floods out again. No mis-fire codes (although 4/5 did show up on 1 scan yesterday.)
It did drive yesterday with no O2 sensor. Still missed though. maybe the coil for cylinder 4/5 would fix it up? Can one or two bad coils cause the whole engine to flood out. The problem is in all cylinders.
Any ideas/suggestions. Thanks
