Hello All,
Not a 60v6 but same concepts apply. This is in regards to my '06 Dakota 4x4, 3.7L Auto. 80k miles.
I know converting to an electric fan from the stock clutch fan isn't going to show much gain, but every little bit helps. It was also very little financial cost since I already had a fan from a Nissan Sentra so I only needed to buy the controller.
Prior to the electric fan install the temp gauge had not ever exceeded the 1/2 mark, it usually sits at just a notch below 1/2. So I installed the fan, wired it up and turned the thermostat on the controller to the highest setting (something the motor would never exceed). Then I let the truck idle up to temp - no fan running. I allowed it to exceed the 1/2 mark by a good bit then I turned the fan on. It brought the temps right down very quickly - OK fan can do the job. Next step was adjusting the thermostat on the controller. So, again I idled it until the engine hit the 1/2 mark then I adjusted the thermostat so the fan kicks on at that point. It seems to work very well, when it kicks on it will cool until the gauge reads just below half, which is where the truck normally runs.
Now, the issue I'm thinking of is what happens when the coolant isn't hot enough to necessitate the fan to run, BUT you have the a/c is on. Well, I gave it a try and with no airflow, the condensor gets incredibly hot very quickly and there is not much 'cool' output at the vents. So, it clearly needs airflow any time the a/c on.
It's easy enough to wire up a relay that is closed the by a/c circuit to power the fan. But, this also means that anytime the a/c compressor clutch is engage the electric fan will run - even at 60mph down the highway. I don't like that very much. On computer controlled fans, when the a/c is on the fans will turn off over XX mph. Not sure how to achieve this on my aftermarket setup.
The only solution I can come up with is to get a 2 speed fan and wire up the low speed side to run with a/c compressor. It'd still run all the time the a/c was on, even on the highway, but that'd be better than running full speed constantly.
Is there anything else I can do to energize the fan when the a/c is on only when the truck is at a stop?
