t3/t4 Garrett advice
    replied
    Ouch, looks like they are still turning a profit on that book. From what I've been told about it, it's worth every penny, though
  • tkoforpresident
    replied
    35$ for Maximum Boost
    But I also picked up an old favourite, The Count of Monte Cristo
    replied
    W00T! Now shut off your computer and get reading! lol. (j/k) What did it run you?
  • tkoforpresident
    replied
    Well, I know Syclones/Typhoons, GN's/GNX's, ect were OBD1 and didn't come stock with a wideband.
    lol true, true.
    btw guys, look what I just picked up at Barnes & Noble (their only copy to boot)
    replied
    Originally posted by tkoforpresident View Post
    Here is a more appropriate question...
    How succesful has tuning turbo's been with obd-1? Especially without a wideband.
    Surely it's not optimal but it's probably been done alot with obd-1 setups.
    I know that there are some masks that are more appropriate than $A1 for a turbo'd motor.
  • tkoforpresident
    replied
    For a pushrod 3.4, 36 lb/hr injectors from a GTP might even work.
    I don't think these will work. They are multec 2 design unless I am mistaken and I need Multec 1 to replace the injectors currently on my fuel rail. Preferably something that is rated @ 43.5 psi.
  • tkoforpresident
    replied
  • tkoforpresident
    replied
    thanks guys, I guess my first question should have been "which book should I read before asking questions on turbos" but since we arrived there smoothly I will go ahead and read that book and then report back with a full report and a plethora of questions
    thanks,
    max
  • timg
    replied
    42.5 lb/hr injectors should be enough. For a pushrod 3.4, 36 lb/hr injectors from a GTP might even work.
    Water/meth injection isn't necessary for 7-9 psi.
    Generally:
    New Power = Stock Power * (1 + Your Boost Level / 14.7 psi)
    Tim
    replied
    Yes, if you are going to even think about doing a turbo, you need to read that book.
  • tkoforpresident
    replied
    You reccomend this particular book?
    If so... I just might buy it.
    replied
    Old material, but the theories still work. Buy and read (or download).
  • tkoforpresident
    started a topic t3/t4 Garrett advice
    What kind of power could be produced running 7-9 psi or so?
    Would I have to use water/meth injection at that psi? How could I avoid not using water/meth injection?
    Is there a general rule of thumb on how big injectors should be based off of desired psi?
    Simple questions for now, thanks
