The product:
The result:
And there is no chance of leaving blast media in the housing.
Next the bearings and shaft go back in.
Then the inner part of the thrust bearing journal.
Then the thrust bearing plate. The outer part of the thrust bearing journal is assembled to the cover, ready to go on.
Then that assembly slides in and the snap ring goes in. It's a tapered ring to keep vibration to a minimum. Therefore it must be firmly seated by expanding it and tapping on it. As the o-ring compresses, the ring expands into the groove, locking the cover in place.
Now for the alignment of the parts, for balance reasons. Look at the turbine wheel. See the number "510" between the 2 blades. One slot to the left, there is a round dot cast into the wheel. This aligns to the drill mark on the housing flange. This was the position before teardown.
The compressor end has an "A" logo (for Airesearch). The first blade to the right (viewed normally) lines up with the scribe mark on the housing.
Then the nut goes on, and tightens to the original position, by lining up the scribe marks placed on them earlier. The mark on the compressor wheel is very small to avoid damaging the wheel. I dotted black Sharpie pen over them to help with visibility.
Finished CHRA.
Now to clean the ash and carbon out of the turbine housing. Wire brush wrapped in Scotch Brite works well.
Result:
Install the clamps with antiseize on the bolts. Line up the drill mark and tighten it.
No carbon in there.
Compressor o-ring
This snapring is a tapered ring to compress the o-ring as it wedges into the slot. It's important to expand it forcefully and tap the housings. This will make sure the o-ring is compressed and the housing is fully seated.
Completed turbo!
I forgot to take pictures, but I had to re-drill the actuator bracket mounting holes. They are threaded into the compressor housing. I rotated the housing to give the air hose a less strained alignment with the charge air pipe on the car body. After that, the actuator holes didn't line up. It took a trip to the store to get a M6x1.0 tap set and a 5mm drill bit. But it will be worth it when the car goes back together.
