everything is for sale! going with the 3500, have to sell al the old stuff....
trueleo short runner intake, painted red, will strip paint before shipping if need be. its ported to the max dia of the ram-pipe (63.5mm)....$350 with 65mm tb $400
two mustang 65mm tbs, one is currently bolted to the trueleo and will only work on that manifold. $50 each
electromotive iac adaptor, comes with iac installed, allows you to use 65mm tb on almost any vehicle...$85
comp roller tipped rockers, 1.6 ratio, less than 3000 miles on them, $100
SIvalves.com's stainless steel valves, swirl polished. they measure bigger than the stock valves on the head of the valve, 1.8 and 1.6 intake and exhaust, $120
crane cams h-11 tool springs pn 99846, good for .6 inch of lift, $120 (i payed $220!)
crane cams valve spring retainers and +.050 locks.....$70
two 3.4 lower intake manifolds...$35 each (no csi port)
modified fuel rail, no csi port, $25
brand new lifters(12), sealed power, $60
crane h-272-2 camshaft, 3000 miles, great shape, USE NEW LIFTERS, $100
clevite pushrods, stock length, $35
3.4 iron head short block, zero decked, bored .020 over, 3000 miles, high volume oil pump, oil pan, timing cover, water pump, timing chain and gears, PICK UP ONLY, $400
2 distributor dummy shafts, for dis conversion, $25 each
7730 ecm from a 91 camaro with prom (has to be programed before you can use it on your fiero!!)...$80
dis coil pack with icm (3 sets of coils with icm for dis conversion) with connectors for conversion...$70
crx cold air intake, modified to fit fiero, with generic blue filter, $15
pictures on request, pay pal only, i ship when money hits my pay pal. all prices are WITHOUT SHIPPING!
post up dibs along with a email to me if your interested. thank you! (merlot566jka@yahoo.com )
 2.8 is a little North of me, though.
