WTB: 3x00 PS pump, Alternator, A/C (for an LX9)
    replied
    Superdave mentioned that on my swap thread. The MPFI RWD brackets are different than my TBI brackets. If I could find a full set, that would be an option for sure. There are pros and cons to both.
    The RWD brackets would be most similar to the Trooper layout and and I could use the same power steering pump and A/C connections, but I don't possess them and they're a little harder to find. Gives me the option of rotating the intake 180º if that proves best.
    One of the main reasons I mentioned it. Too bad it's winter and browsing the junkyards isn't much of an option at the moment.
  • Canyonero
    replied
    Originally posted by Rootie524 View Post
    don't have the lines but the pulley is on it and it does look like it would bolt up. as would the a/c in the front there by the oil filter. want a pic?
    Yes please.
    I'm a little foggy on where/how that compressor bolts on, and what that means for my RWD motor mounts.
  • Canyonero
    replied
    Or maybe go with a RWD timing cover and go with Camaro/Firebird accessories kind of like the hybrid guys?
    The FWD setup is lower profile, leaves more room to work with at the front of the engine. But I would not be allowed to rotate the intake 180º. Not such a big deal if I'm going to modify the plenum for a side inlet. However that leaves the thermostat at the rear of the engine.
  • Rootie524
    replied
  • Canyonero
    replied
    Turns out I was incorrect, I do have a timing cover that will take a power steering pump. Would yours bolt up to mine? Have the pulley and lines as well?
  • Rootie524
    replied
    i have a 3400 timing cover, power steering pump, and a/c compressor. lmk if you need anything.
  • slinky
    replied
    I have a 3100 timing cover as well if that would work for you
    replied
  • Canyonero
    replied
    I don't see where the PS pump would mount. Am I out of luck unless I get a timing cover from a PS equipped engine?
    replied
    You are probably right on the electric assist steering. There were a few vehicles from about that year that got it. Malibu was another one coming to mind.
  • slinky
    replied
    I have an alternator in like new condition, used for about 2 months, paid $105 for it at advance auto, make me an offer email me at phel0z@yahoo.com
  • Canyonero
    started a topic WTB: 3x00 PS pump, Alternator, A/C (for an LX9)
    I'm working on an LX9 swap. I'm trying to figure out my accessories. I'd like to get my hands on a power steering pump that will fit. Doesn't appear one came on this LX9 from an '05 Uplander (electric?).
    It would complete the system if I could also find an alternator and A/C compressor.
