Originally posted by 90BlueZ
									View Post
Wtb tce drtc!
Sorry if that's what his gear cutter is going to say when the chain is walking out of the sprocket that's just not the whole story... One chain didn't fit and walked out 1 tooth, the other fit and only because it was badly stretched.Originally posted by 90BlueZ View PostI just shipped mine back today. Marc gave me a bit of an update at the same time, I hope he don't mind me posting it here to keep people updated with progress
"So far I have found two upper sprockets that are out of tolerance but .002" and the gear cutter said that really should not have an effect given the chain length and diameter of the sprocket. The funny thing is, the two Jon (3400modified) sent back were well within tolerance. The problem appears, at this point, to be the lack of oil grooves in the back of the sprocket causing the chain to run dry and wear prematurely. You can see heat marks (blue) on the back side of the one Jon had in his engine. This shows there was a lack of oil getting to the back side of the sprocket which also slings out on the chain."
SOMETHING is wrong, Maybe it's the chain at fault... I don't know, but it's not right. This was not caused by lack of lubrication I can guarantee that.
If you take a bike sprocket and a chain and you wrap that chain fully around the sprocket, it fits... PERFECTLY... This chain did not fit into these sprockets it would center on one roller and then every other tooth after that it would begin to walk out of the teeth. If he is measuring to the profile of a Cloyes DRTC set for the 3.4 camaro and it's coming up right then he needs to measure the chain too and make sure those are the same profile.Last edited by 3400-95-Modified; 09-09-2013, 03:47 PM.
We are coming up on 3 months from when I discovered this issue... I hope something is figured out soon...
I sent an email Monday asking for updates and honestly don't expect a response, just kinda hoping.
I emailed him again asking for a response, I hope he's doing well, but at the same time, it doesn't take much effort to send a mass email."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
My set is from the original batch, tce stamped, oil grooves, but no advace key ways are cut. For those that done know i got 20,000km on 2 chains, caught the ugly noise the first time, second time it was a knock and sounded like my tensioner was fucked, so maybe its partically my fault, but my top end needs to be replaced now
i'm having troubles getting a GM style chain from a 99-pre motor, according to the parts stores when i brought in a original gear set from a gm motor they told me its aftermarket and doesnt exsist. so i cant even get a melning chain set. guess i'll over night a GM Chain and slap this bitch together. hopefully for the last time.
I emailed Marc again, and still haven't heard back. I hope he's alright."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Find a new autoparts store... I'm using older OEM sprockets and I just picked up a 96 Beretta Chain from Advance Auto. SA Gear was the brand, I also grabbed an SA Gear dampener.Originally posted by bob442 View PostMy set is from the original batch, tce stamped, oil grooves, but no advace key ways are cut. For those that done know i got 20,000km on 2 chains, caught the ugly noise the first time, second time it was a knock and sounded like my tensioner was fucked, so maybe its partically my fault, but my top end needs to be replaced now
Summit has Melling, but I don't know if it's any good... http://www.summitracing.com/parts/me.../model/berettaLast edited by 3400-95-Modified; 10-17-2013, 09:19 AM.
