ok so i have more sensors for sale. all used from my 02 GAGT but in good condition, all prices are for part only, shipping is extra
1. Stock 02 gagt preprogrammed PCM. just had this one programmed for my car, but i got the DHP PCM, so im going to use that. PCM is $70 plus shipping
2. Front headlamp assy. right side(or pass side). very very littla hazing. just the headlamp. $20 plus shipping
3. Stock water piping from water pump to heater hose(includes quick connect fitting) also includes brass fittings, in very very good shape. water pipe is $12 plus shipping
4. Lower Air Baffle - part that focuses the air to the radiator and up to the top of the radiator...also a good tool rest when the bumper is off, slight cut in pass side for a street glow kit i used to have...$5 shipping extra
5. (2) TPS sensors and 1 IAC - TPS sensors are almost new...maybe used for 1 month on one and about 3 on the other...they are from other parts i bought and other ideas i had...didnt work out. IAC, in good condition, one of the ears is a little broken, but will still hold and not leak---TPS $15 a piece and IAC $20 shipping extra
6. pass side lighted window switch, used has some of the paint scratched off, switch works, but dont remember if the light does---$5 shipping extra
7. UIM off 02 gagt, has new style EGR... UIM $50 stock unported and cleaned shipping extra
8. LIM off same car, also pipe plus quick connect fitting---has press in style fitting---pipe is $5 with fitting and LIM is $70 cleaned, or $72 together, shipping is extra
9. Drivers side fog lamp. has hazing on it. includes lamp, bracket and assy. will also include an article on how to remove the hazing on the lamp. $20 plus shipping.
10. stock 02 injector harness, missing one weather rubber and green positive clip to retain the injector in $20 plus shipping. just missing 1 positive green retainer
11. two brand new Eagle eye replacement headlamps for 99+ GA. do not include bulbs...srry exact stock fit and look $120 plus shipping. look at the thread for pics (http://www.grandamgt.com/forum/showthread.php?t=66060)
12. Stock Ram Air setup for sale. includes upper air baffle, smoothed ram air box(upper and lower) elbow for fenderwell and ram air ducting from front bumper. also includes baffled tubing. $40
13. Stock 02 gagt heads. will include rockers, valves, springs, retainers, locks...174K mi on them, never overheated or anything. $100 plus shipping. 10mm rocker bolts IIRC.
14. Stock springs from another set of heads 2004 gagt valve springs with about 54k mi on them. $30 plus shipping.
15. Stock spring seats/seals for 04 heads, all 12, $5 plus shipping
16. 3 stock torqued 5 spoke PY0 rims. $70 plus shipping each, and dust caps, all 3, are $15 a piece, or with rim is $80 total. if you buy all 3 covers and rims, the price is $200 plus shipping. 2 rims have very slight dents that do not effect balancing.
17. throttle body heat shield from PFYC $10. ------sold
18. Brand new ignition control module, never taken out of plastic, has 3 months left of original 1 yr warranty. $65 plus shipping
19. brand new Fel Pro Lower Intake Manifold Gaskets. these are the 2nd revised edition IIRC, but they are part of the plroblem solving kit that felpro makes. they are plastic and are brand new. will even come in the original box. $15 plus shipping
if there is any more ill post up again. ill take paypal or money orders, or cash.
20. MAP sensor - stock, still works good, asking $15 plus shipping
21. Coolant temp sensor off my LIM...still works 100% good. no problems. $10
22. Front crank sensor - still in good condition. $10
23. Internal Crank Sensor - very good condition - $8
24. also i have my stock tensioner assembly off my car. it was working great when my car still ran. asking $12 for it. no guarantee on it, but it has no signs of wear and no leaks from the bearings or bolts.
25. also i have a complete genuine GM 6 way power drivers(or passenger if you can wire it) adjustable motors on the plate. they also come with 1 new actuator for the seat. they are brand new and never even touched at all. asking $60 for all of it. shipping extra
