Originally posted by pocket-rocket
View Post
in the near future (and by near, i mean when i confirm that all of the 3BAR stuff is working 100%), i will have options setup to allow the wideband to be used for closed loop fueling control as well.
knowing me, i'll have another option that will allow the WB to adjust AFR in PE as well, if the read AFR isn't matching the commanded AFR.
and probably yet another option to use the F56 (open loop target AFR vs MAP vs coolant) table as a WB closed loop target AFR table. it already goes from 20-100kPa and -40 to 241*F, so i'd say it doesn't really need expanding. maybe a RPM/TPS modifier so that in situations where MAP would be similar(800RPM and 40kPa idle compared to ~1600RPM and 40kPa while coasting down from speed), a different AFR could be commanded for each situation...
oh, the possibilities.
