I've been working on a master pinout for the 16236757 and similar obd2 60V6 PCMs thought I would share my progress, anything labled "O" I don't have info on. I've attached the sheet as a PDF.
some interesting notes:
I've made a table of the different vehicle pinouts, that show's which vehicle used which pin, it can be viewed here:
I tried posting it here, but this site didn't like the table, it just made a big ugly list...
here's the list style:
Blue PCM connector pins
1. Transmissino fluid temp Sensor ground
2. 2nd gear start indicator
3. Fuel level output
4. Shift solenoid a
5. Fan 2
6. Fan1
7. Cam position sensor input
8. Low frequency crank position
9. High frequency crank position
10. 5 volt reference
11. O
12. ECT ground
13. Map ground
14. O
15. Serial data
16. PCM ground
17. IAT Ground
18. O
19. Ignition Feed
20. Battery Feed
21. O
22. Transmission range A
23. O
24. O
25. O
26. O
27. HO2S
28. HO2s
29. HO2S
30. TCC brake input
31. EGR pintle position sensor ground
32. EGR control(EGR Ground?)
33. Bank one knock sensor
34. Bank two knock sensor
35. O
36. Alternator charge warning lamp(generator control?)
37. O
38. IAC B High
39. Fuel pump speed control relay
40. O
41. O
42. O
43. Injector control (1 60v6/6 for 3800)
44. Shift solenoid B
45. AIR valve control
46. Injector control (3 60v6/4 3800
47. Injector control (2 60v6/5 3800
48. Reference low (IGN mod ground)
49. O
50. O
51. O
52. O
53. Ignition control bypass
54. Ignition control
55. VSS output
56. PCM ground
57. PCM ground
58. ClassII (? typo maybe, 2000 grand am 3.4 pinout)
59. Class 2 serial data
60. PCM ground
61. TPS ground
62. Input shaft speed sensor low (4t65e)
63. Input shaft speed sensor high(4t65e)
64. VSS high in
65. VSS low in
66. O
67. O
68. Transaxle range position switch B
69. MAF Signal
70. Theft deter fuel enable
71. Traction control desired torque input
72. Cruise control inhibit
73. Injector control (5 60v6/2 3800)
74. O
75. ECT hot warning lamp
76. EVAP purge solenoid
77. O
78. O
79. Injector control(6 60v6/1 3800
80. A/C pressure sensor ground.
Clear connector
1. O
2. EVAP canister vent control
3. Fuel pump relay control
4. EGR Valve control
5. SES light
6. Low oil light
7. IAC valve A High
8. Tach output signal
9. Traction control delivered torque control
10. HO2S signal
11. HO2S signal
12. HO2S signal
13. O
14. O
15. Transaxle range switch P
16. PNP switch signal?
17. Transmission range C(4L60e)
18. Transaxle range switch A (clutch anticipate switch)
19. Oil pressure switch
20. O
21. 2nd gear start signal
22. A/C request
23. Crank signal?
24. Ignition positive voltage
25. Map sensor signal
26. ECT signal
27. A/C pressure signal
28. EGR pintle position signal
29. generator pin F
30. 5 Volt reference
31. O
32. Fuel tank pressure 5 V ref A
33. 5 volt reference A
34. 5 volt reference B
35. Fuel tank pressure/level Sensor ground
36. Change oil lamp
37. O
38. O
39. A/C compressor relay control
40. O
41. O
42. Injector control(4 60v6/3 3800)
43. O
44. IAC valve A Low
45. Pressure control solenoid high
46. Pressure control solenoid low
47. O
48. 3-2 solenoid control
49. IAC valve B Low
50. IAT sensor
51. O
52. O
53. O
54. O
55. Fuel tank pressure signal
56. Transaxle range switch C
57. Transmission range B (4L60e)
58. Oil level signal
59. Cruise status
60. O
61. Generator terminal L
62. O
63. TCC release switch input (4t65E)
64. O
65. O
66. TPS signal
67. O
68. Trans fluid temp signal
69. Fuel level sensor input
70. High frequency crank position ground
71.
72. Cam position power supply
73. Cam position sensor ground
74. High frequency crank position power supply
75. AIR pump relay control
76. Starter enable (VATS?)
77. Boost control solenoid control circuit
78. TCC PWM solenoid control
79. TCC enable solenoid control
80. O
- there are 3 O2 sensor inputs on this PCM, one for each bank, and one for post cat
- some 3800's use the same PCM's, and have dual knock sensors.
4. Shift solenoid a
5. Fan 2
6. Fan1
11. O
12. ECT ground
13. Map ground
14. O
15. Serial data
16. PCM ground
17. IAT Ground
18. O
19. Ignition Feed
20. Battery Feed
21. O
23. O
24. O
25. O
26. O
27. HO2S
28. HO2s
29. HO2S
30. TCC brake input
35. O
37. O
38. IAC B High
40. O
41. O
42. O
49. O
50. O
51. O
52. O
55. VSS output
56. PCM ground
57. PCM ground
60. PCM ground
61. TPS ground
64. VSS high in
65. VSS low in
66. O
67. O
69. MAF Signal
74. O
77. O
78. O
Clear connector
1. O
5. SES light
6. Low oil light
7. IAC valve A High
10. HO2S signal
11. HO2S signal
12. HO2S signal
13. O
14. O
20. O
22. A/C request
23. Crank signal?
26. ECT signal
29. generator pin F
31. O
36. Change oil lamp
37. O
38. O
40. O
41. O
43. O
44. IAC valve A Low
47. O
49. IAC valve B Low
50. IAT sensor
51. O
52. O
53. O
54. O
59. Cruise status
60. O
62. O
64. O
65. O
66. TPS signal
67. O
71.
80. O
