i have a 1988 corsica with a 2.8(3spd a/t tranny), there is a pretty heavy knocking sound from under the front head, i took off the rocker arm cover, there is almost no oil pressure out the push rods. i think the oil pump went and possibly caused a rod bearing or lifter to go(causing the knocking).
i have a friend with a 3.1 with only 130K on it, he flipped it and caved the roof in. i'm thinking of putting his motor and tranny(4spd a/t) in. the pcms are both the same, with different proms, can i just swap the motor and tranny, hook up the bulkhead wiring harness connector, change prom and be back off to the races.
any insight would be appreciated
