Does anyone know what would be needed to swap a 3500 into a 2002 Monte Carlo that came with a 3400?
3400 to 3500 engine swap
an external crankshaft trigger, you'd have to swap in the 3400's fuel rail and injectors.. also pick up a TB adapter from the wot-tech store so you can use the 3400's TB on the 3500 plenum
other then that it should be an easy swap. It's been done in a 99 grand am GT and a few Cavaliers that previously had 3400's
