I have had constant issues with the 3400 in an 2001 alero.  Finally after 160000 it has become more cost affective to buy a 3500 LX9 engine from a 2005 G6 then to try to rebuild the 3400.  Can some one give me some detail as to what difficulties I'm going to run into.  I have seen some of the other discussions about this same subject but on much older cars.  Please keep in mind with your answers I have some car experience but this will be the biggest job I've tried to do.
Will the sensors match up (for the most part)
do I need to swap the plenum with the 3400
does the front cover need to be swapped out.
Will the ac mounts work from a 2001 to 2005.
