Honestly, swapping a 3.5l into a 4th gen F-body is enough of a pain. the problem lies in the fact that cowl sits so far out over the top of the engine making it difficult to swap motors with high intakes. DOHC engines can be nearly 5-6 inches higher than than a Push-rod 3.5-3.4l.
Im swapping a 3.5l in my F-body right now and I had to lower the engine in my car by nearly 2.5 inches (maybe lower) to get the upper intake to clear the cowl. Unless you intend to do a serious amount of sheet-metal slicing, I suggest you stick with a 3400/3500 swap. They are not easy swaps, but at least the engines will fit without chopping up the cowl.
2003 3.2 cadillac dohc swap into camao?
Is this the punched out version of the german made 3.0L found in catera's, L300's, and few others? All I can say is, what a pain to work on, someone had the bright idea to bury the coils near the fire wall on the back of the intake. Also has an oil cooler under the intake that tend to fail, prone to valve cover gasket failure, warped valve covers, and they like to eat timing belts from what i hear. Otherwise, its a perky motor, and the parts are expensive. I'd sooner swap a 2010 3.6 camaro and deal with the elctronics issue instead.
I would assume it's drive by wire. You might also want to look on HP Tuners website and see if that car is supported, otherwise you might ses up with a huge mess of electrical and electronic fits with the drivetrain control system.
Does anybody have any info on this motor? i have a 1994 3.4 camaro. i was thinking about either a hybrid or a full 3.5 swap. but i found this motor on craigslist for cheap and was wondering if it would be worth it. but i dont know much about the motor itself like ignition and stuff. i think its drive by wire but im not sure.Tags: None
