Hi everyone. going by this guide:
http://crzyz28.sytes.net/images/bann...swap-guide.pdf
This swap should be pretty easy as swaps go. The guide focuses on 95 cars, but from what it says, since mine is a 96 it should just be even easier right? Mainly the reason I want to do this is because I can't find any 3.1L engines around, but there are some 3.4L engines. Since the 3.1L plenum is supposed to flow pretty good, I think I will put that on the 3.4L just because I can.
If that is the case then what I need is an engine hoist, what I will probably end up doing is getting someone with a crane on their pickup truck. The original engine is in pieces, so I may have to bolt the heads back on and lift it out that way. I don't know how the transmission comes off the engine, does it just slide off once you unbolt it?
Mainly what I want out of this is a relatively reliable car that can move out of the way when it needs to. I would appreciate any tips on improving MPG, and on inspecting potential engines.
