92 Olds Cutty Supreme 3.4 DOHC Getrag 284.
i dont know if anyone else has had these problems but maybe i could get some help. have a really bad rattle coming from the trans when clutch is out. in nutral or i can hear it when i let the clutch out and the motor is at low rpm im gear. push the clutch in it all goes away. thats why i think it is the input shaft bearing
so now anyway the clutch is on the rivits and was soked with oil cuz i think the seal in the input shaft bearing went. so i figured the trans was low on oil but it needed a clutch anyway so i put it off.
till today when the trans starts really fucking up. its like the input shaft really doesnt want to turn. makes really weird noises and is a biotch to get in gear. like ram it with all i got to get it to shift.
so i plan to take the trans out oviously and get a new clutch in there. then ill know for sure what is going on with the input shaft and bearing. but i dont even know if i can get a input shaft bearing....
any help in anyway greatly appriciated.
