is this a complete swap with the 4t65e? i just wanted to make sure. as in are the transmissions exactly the same size that it shoudl bolt right up? thanks
4t65e-HD
The tripot(axle end trans side) are bigger. I think that is the only dimension externally that is different....It may also be a hair longer.Lorenzo
I think people do a half and half axle setup. The inners from the 65 and outers from the 60.
325 whp 350 lb-ft
