After a week of suspicious behaviour I had a look at the fluid. It was still red but I couldn't see to the bottom of a cup like I could with fresh fluid. I changed the fluid and filter about 3 months ago so something's definitely not right. The car still drives ok but acceleration is sluggish below ~2100 RPM and doesn't creep at idle as fast as it used to. Shifts in all gears are still strong so I'm thinking bad convertor or burnt clutches. To be safe I dumped the fluid and topped up with new ATF.
Anyways I know I need a rebuild soon. I'm not looking to do anything crazy though as spend-mas is coming. Should I go with a standard rebuild kit or should I look into the aftermarket Raybestos (or other?) frictions? I'll definitely ask about a 35/35 sprocket set to replace my 37/33 set.
