I have an '88 s-10 p/u 4x4 that has a 2.8L engine/700R4 combo. I had hoped to wait until I bought another daily driver before I did any major work on this truck, but my trans is on it's last legs now. It stalls out if I drive it more then a mile or more, and a few times after putting it in park and shutting the engine off, it'd start to roll on me!
Definetely time to have the trans rebuilt or replaced. The thing is, I really wanted to swap the engine out and install a hybred 3.4L, as discussed here and other s-10 boards. This will require an upgrade from the 700r4/4L60 to a 4L60E. I just can't see spending money on a rebuilt 700R4/4L60, only to have to buy a 4L60E down the road. Even if I don't put much milage on it, I won't get what I paid for it.
So....Looking at my copy of the Haynes repair manual as well as doing some heavy googling..I know that there were some s-10's that had both the 2.8L engine combined with the 4L60E transmission installed at the factory.
I know in order to get a 4L60E trans to work in my truck I'll need to find a ecm for it. What I don't know how to deal with is, do I need to replace the entire engine wiring harness, or is there a way to adapt in the proper 12 wire harness that'll fit the 4L60E trans? Also, my truck came with a mechanical speed cable. From what I've read, I need to convert this some how so I can send a VSS signal back to the ecm in order for it to know when to send the signal to the trans to shift gears.
Beyond all this is there anything else I would need to do to convert over to a 4L60E?
I know this seems like a big head ache to do this type of swap. Esepcially since I'll need to swap ecm's once again when I install the 3.4L engine. But that sure beats he heck out of loosing $100's buying two transmissions!
And while I have asked at local bone yard, I can get a trans from them for $140, but they won't cut it out for me. And that's a ton of work not knowing if the "new" trans isn't as bad or worse then the one I have now.
Comments? Suggestions?
thanks
Jax
thanks
Jax
