anyone have any experiance with the f23 getrags??? i know there is a wide range of gearing avalible for them, aswell as a couple limited slip diffs. now gm doesnt rate them for much (165ft/lb torque) but i have heard of them holding 400+hp behind ecotecs.
now i know the 2.2l ohv used the getrag f23 00-02, and i know they are the same bolt pattern as a 60 degree. i was tossing the idea around about swapping one behind my ironhead. my biggest concerns are the clutch (release heights and making the internal slave work right) and the tranny holding up. the shifter is easy, grab a 2000+ cavalier shifter and cables and drop a b&m short throw into it. i would end up welding the mount brackets from the 2000+ into my car, giving me 4 good mounts.
any thoughts
any thoughts
