mrz udp
  • El_Diablo
    replied
    you mean damper, right? theres no reason to externally balance these engines....
  • andrew383
    replied
    the overdrive alt pulley is like 50 bucks
  • 19Cutlass94
    replied
    I know I could get a pulley, but Im gonna put the harmonic balancer on the 3400, then i can run an upgraded Alt, to help with my stereo.
  • El_Diablo
    replied
    not sure why everyone freaks out either... seems to happen atleast every other month *shruggs*
    only reason im selling mine is because i dont HAVE to have it for my build and i need the money for another car, sick of walking in the rain
  • geldartb
    replied
    OMFG!!!!
    I went 62k on a 3400 with a UDP installed from day one, and it was head gaskets that caused the motor to be removed... Plus I built the hybrid.
    This debate isn't new news so I dont know why everyone freaks out and is all like... MAN that left a bad taste in my mouth when I found out. I knew of this debate from day one and I wasnt worried about it.
    i was witness to the headgasket failure. and i had the antifreeze on my windshield to prove it.
    Originally posted by 19Cutlass94 View Post
    If it wasnt for the damn voltage drop at idle I would run one. but as it is right now, its killing me.
    bam simple solution prob take 5 min at the most
    replied
    That can be fixed by a diode or putting a slightly smaller pulley on the alternator... remember your water pump and PS pump will still be slightly underdriven... so your not totally removing the purpose of the pulley.
  • IsaacHayes
    replied
    Heh, I have a bad voltage drop cause my battery is about dead. When cranking it drops to 8volts then the car will sometimes want to stall out cause the DIS has such low voltage, so I have to tap the gas to get it revving up the alternator and then the voltage flies up to 14v Yeah I need to replace it, it just hasn't let me down yet forcing me to lol
  • 19Cutlass94
    replied
    replied
    OMFG!!!!
  • El_Diablo
    replied
    FFP includes a sheet that states they aren't liable
    we dont use harmonic balancers!!! its a damper!!!
    side note, due to me wanting to purchase a dodge daytona my pulley is now up for sale for $100 plus shipping if anyone wants it (ive never installed it), still got a lot of other parts in the FS section aswell
    gotta get my lil plug lol
  • silvergtjrad
    replied
    Originally posted by andrew383 View Post
    thats like saying if you smoke a cig its your own fault for smokin it,they have to say somthin bout the possibility of failure?
    They are going to tell you to screw off if you blame them for your engine failure. Either buy it or dont, and its going to be at your own risk. Unless you are willing to spend thousands of dollars to take them to court, over an engine you could replace for a fraction of that. You dont drive a race car, its going to be fine. There are plenty of people with the UDP who have had no problems, including myself.
  • andrew383
    replied
  • 19Cutlass94
    replied
    Nope. If you use a UDP, you taking that risk on your own. They are not responsible for any damage that might happen to your engine.
    FFP, MRZ, ASP, are all not responsible for this.
  • andrew383
    replied
    did you contact asp about any engine failure possiblity using the udp???
  • 19Cutlass94
    replied
    In the picture I posted with the two side by side, The black pulley was the Harmonic Balancer, which has the rubber in it. the smaller silver pulley was the UDP which does NOT have any rubber in it.
