Pull each plug wire (one by one so you don't mix them up) and put a spark plug in it and stick it on something metal on the engine and have someone crank the engine. Watch for a spark to jump the gap on the spark plug. If you see one, unplug the plug, put the wire back on it's spark plug, unplug the next one, plug the spare plug in it and repeat. Also look to see if your spark plug wires are crossfiring/leaking. Pop the hood when it is dark outside (the darker the better) and run the engine and look for sparks jumping out of the wires. If you see any, that wire is bad and needs to be replaced.
