i was thinking and i cant figure out why a 3.4l 260h comp cam wouldnt work in a 99 3400 block? they look identical and both use the same camshaft position sensor, thats mounted at the same place? i dont have a 3.4l cam here to compare but it seems like it should work... both use camshaft bearings too. I would hate to spend $350 on a wotech cam and wait 3 weeks to get it when i could get a good Comp cam for $140 from summit and have it in a week. any thoughts?
94 iron head camshaft in 99 roller camshaft block
Cam designed for iron heads vs aluminum heads. 10 more degrees duration, .030" more lift than the stock cam. About 6-8 hp increase. Flat tappet vs Roller. 3 bolt timing set vs 1 bolt. No idea if the CPS is compatible with the iron head cam.Last edited by SappySE107; 06-20-2016, 12:25 PM.Ben
thanks. i figured it out though, the flat tappet cam lobes are cut at an angle so the lobe spins the lifter as it rises, a roller cam lobes are cut straight so it would destroy the lifters and cam unless i convert to flat tappet lifters and timing set, but that would be counter productive. do you know how big of a ratio rocker arms you cam run of a 3500/3400 hybrid? i see 1.7 and 1.8 ratio arms i would just have to get a stud conversion set from arp (8mm to 3/8")Originally posted by SappySE107 View PostCam designed for iron heads vs aluminum heads. 10 more degrees duration, .030" more lift than the stock cam. About 6-8 hp increase. Flat tappet vs Roller. 3 bolt timing set vs 1 bolt. No idea if the CPS is compatible with the iron head cam.
