I've ripped apart my share of engines but, putting them together I'm new at. So I took apart my 3100 that I broke and some water/antifreeze came out when I took the timing chain cover bolts out. I'm putting together a 3400 and my question is do I have to put sealant on any of the timing chain cover bolts, if so all of them or just certain ones?
Also, while I'm asking questions I have another question. Can I put the Melling high volume oil pump that I had in the 96 3100 into the 03 3400 I'm putting together? Also, the pick up tube had to be welded on the pump so compared to the factory pump from the 3400 it's about an 1/8" higher up away from the oil pan. That is the main reason I think I shouldn't use it. Correct me if I'm wrong, should I put the high volume pump in?
Thanks for the help
Jason
Thanks for the help
Jason
