Getting ready to remove the garbage 3400 from a 2000 Alero and put my rebuild in and the bolt that sits right above the starter is behind the "engine mount" on the trans. It looks like I could get a socket behind there except there are trans lines going into the trans to the right of all that that seem to be in the way.
Am I going to have clearance to get a socket/extension back there or will I need to support the trans and pull the mount? Do I just pull the trans lines?
Anyone ever run into this and have any good advice before I go pulling apart everything?
