Recently I bought a bluetooth OBD2 reader, and the Torque App. There are no trouble codes, but in the data feed while the car is running, it says the timing is running at 19.5 to 20 degrees btdc, which is far too much. Idle is a bit noisy, but overall running condition seems fine except for some hard starts when the engine is still warm, but very low on power and torque.
Could the timing chain have stretched, and jumped a tooth, and the computer is just compensating by advancing the timing?
Sorry, i'm a little new to OHV, and OBD2 cars. I am used to working on pre OBD2 mazda four banger engines.
I know the timing chain probably needs changed anyway on this engine, since I am sure it is still the factory one, but I am just trying to figure out if this timing issue is causing the low amount of power and torque, or if the engine is just worn out.
Engine has an unknown amount of miles on it.
