3500 swap questions
This is a sticky topic.
Yes.
3900 adapter with 75mm throttle body from the Northstar
Cam (was suggested a 1393 grind for a DD)
External Crank Trigger
Custom Pushrods
COMP Cams Springs
Anyone have any info about getting this TB to work? As far as the IAC goes and the linkage. I know someone has done it/was going to and I can bolt it to the manifold with the 3900 adapter so it must be possible.
Ah so you are going with stiffer springs? Going to boost or cam it then?
It has a 6 month warrenty so everything best work heh. It was $550, it's from a 2004 Malibu with 10k miles.
I bought a project car to do it to, another 96 white GP, but a 2 door. So I have 2 96 white GP's in my driveway.
Right now I am preparing to get everything I need. Will order everything very soon from the store here that I need. Also figuring out what special tools I will need. So far I know a valve spring compressor, and some sort of valve air hold thing that goes in the spark plug holes to keep valves from falling in when the springs come off.
What size of air hold tool would I need for these heads? Any recommendations?
Thanks.
Great! You're going for it!
Did you get a 2nd car to hot rod or are you doing it to your bright white? I'd defiantly get a DHP after you're done so you can fine tune it and get every last HP out of it.
I believe it was found out that the 3500 O2 sensors are not compatible with the older ECMs... So might want to re-use your old. It would be nice if you could use them though since they are so new..
No Oil? I hope they didn't write that on there because they cracked a hole in the oilpan!
Keep us updated with pics!!!
Got the engine today, here are the pics. They are full resolution to see details, so I am just going to link them.
did your exhaust manifolds come with flanges attatched? I need a couple front 3500 "header" manifold flanges. If it came wiht it, pics at least?
I'd guess one could if they do custom stuff. Have them weld in an O2 bung where it Y's. Go with 2.5" exhaust and a high flow cat and a straight through muffler while you're at it....
Or you could put your O2 in the rear manifold but it would only read one bank.
Oh interesting...
I wonder if an exhaust shop would do it for me.
That's cause the header style is like headers and doesn't have a cross over. They connect with a Y pipe under the car. You'd have to do something similar.
I've already seen the engine and they appear to be header style, their from an 04 Malibu. However it didn't look like it came with a crossover :-/
Dunno, you have a W body, so you have more room for the down pipe than J or L bodies do. I know on a J body you can use two FRONT mounts and it will work. You may be able to use them as is. And I've heard the manifolds can vary and be log style or header style on the 3500.
Well regardless I'm getting the engine tomorrow, it'll go in there somehow :-/
Let me guess, the 3500 manifolds (the ones that turn down and go under the oil pan) won't fit, will they?
Well the passenger side is the side to be concerned with since the drivers side it's bolted to the transmission and thats bolted to it's own mount.
I'd look down low by the craddle. Since you don't have a side mount, you should have something else down below I would assume...
EDIT: seems you have an anchor mount and maybe another mount somewhere.Last edited by IsaacHayes; 05-21-2007, 09:40 PM.
Yes I have front/top dog bone mounts that go to the heads. As far as a lower/side one, I am not sure since I can not see anything. Where exactly should I look?
