Adjustable rocker arm stud swap in '92 3.1L
  • #31
    LOL yeh I saw those other ones but I'm not sure if I want to spend that much (more) money. The ones I was looking at are basically the same as the ones that came with the rocker arms.
    I'm sure they are more reliable, but the others should work fine, yes? I don't plan on racing this car every time I drive it. I just wanted a little more mid- and high-range power to pass the slow folks.
    Well looks like that's confirmation they should work. Anyone know of a place to get the pivots for, hopefully, $20 or less? I'd rather get new ones, otherwise I know people who work on SBC and I'm sure I can get some used ones off of them.
    • #32
      There are much cheaper adjusters out there. ARP's are of course the most expensive. Try COMP and Crane. And try a Local supplier because Jegs and Summit are often not the cheapest.
      • #33
        Alright I checked Crane and Comp. Crane didn't seem to have any pivot balls sold separately, but Comp does make and sell them:
        Looks like those 3/8" are what I need. However, I hope the price is for a set of 16 and not for just 1 pivot! They don't really clarify how many you get for $13.
        Again I'm quadruple checking I get the right things this time before I even buy the suckers. I've been working on my car, on and off, for 6 months now and I want to drive it so bad. But the 6 months have been hell with bolts breaking off, auto parts store giving me the wrong parts, and learning for the first time. I really want to get it right since so much has gone wrong already.
        • #34
          PART #1400B-16
          The 16 at the end usually means that there are 16 pieces.
          http://www.compperformancegroupstore...&Category_Code=
          As you can see, the 1 at the end means only 1, and that they are $0.79 each.
          • #35
            Thanks for the clarification. I was 99% sure the 16 did denote how many there were, but I just wanted confirmation from someone who's bought this stuff before. Looks like I'll be picking those up.
            So, I should be good to go with:
            12 of 1400B-1 3/8" BALL
            and
            12 of 1400N-1 3/8" NUT
            from Comp, right? I know those nuts are cheap, but they should be self locking, correct? Here's the page (with drop down menu) I found them:
            This website is for sale! compperformancegroupstores.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, compperformancegroupstores.com has it all. We hope you find what you are searching for!
            I'll go with the replacement nuts as long as they lock down.
            • #36
              Well I hope they work for you. Just remember to limit the adjustment you do to them.
              • #37
                Well boo, I took a really close look at the studs and they do have a little damage:
                The picture is big so you'll have to zoom it out. I had to put the thing in a scanner because my camera sucks balls. Looks like they are still useable, but I don't want to end up damaging or shortening the lift of the nuts if I don't have to.
                I did find a rocker nut from a SBC head in the garage and put it on one of the studs. I didn't tighten it down all the way because it was starting to take a lot of torque just to get it to the pivot ball, so I stopped because I didn't want to ruin the stud or nut. I'm not even 100% sure it was 3/8", but I assumed it was. 5/16" probably wouldn't fit, would they?
                I also came to a revelation that I can probably put the OEM studs back on, get a washer, torque the nuts down, and not have to take off the intake. This would save a little time and I could get my car done sooner, since I wouldn't have to wait for nuts and pivots to ship to me.
                Anyone wan to confirm if I can replace the studs without taking off the intake?
                Also, if anyone knows the thickness of the washer needed for the 1.6 roller rockers, that would be great too.
