How much can the compression be increased without changing pistons? I've been reading for quite some time, and I can't seem to find exactly what I want to know. Can 0.040" gaskets be used? Are they available in a 3.8" bore without getting into something custom? Or is there not enough piston to head clearance? I tried using the CR calc, but I can't for the life of me find an exact number for the dish volume of the 3500 piston. But from what I could see, if the heads could be milled 0.020", and a 0.040" headgasket used, it should bump the compression up to about 10.8 correct? And then what about piston to valve clearance?
Increase 3500 compression without changing pistons
Yes you can shave the heads .020 to gain a little SCR but you will lose .020" of clearance to the pistons
No, you cannot use .040 gaskets
3500 pistons pop out right about .020"
Piston to valve clearance shouldn't be a problem unless you are running a large cam.
search for posts made by me for some carnage pics of piston to valve clearance problems.Last edited by Superdave; 02-19-2008, 11:44 PM.
I can't agree more. When I measure the 3.4 pistons (.0095") I could hardly believe that GM had a .0305" quench - guess it didn't matter when the engine died at 5500RPM, lol.Originally posted by Superdave View PostYes you can shave the heads .020 to gain a little SCR but you will lose .020" of clearance to the pistons
didnt the valves hit the pistons cuz of the rod seeing 7k alot?Originally posted by Superdave View PostYes you can shave the heads .020 to gain a little SCR but you will lose .020" of clearance to the pistons
search for posts made by me for some carnage pics of piston to valve clearance problems.[SIGPIC]
12.268@117... 11's to come!
You aren't going to see an increase in compression (well, maybe a fraction of a percent) if you shave the pistons just to use a thinner gasket. The only increase you will see is from a now very slightly smaller piston dish volume.-Brad-
Don't forget the 238* duration on the camOriginally posted by MidnightriderZ24 View Postdidnt the valves hit the pistons cuz of the rod seeing 7k alot?
I'm trying 236* and have more clearance with .0095" pistons/.060" gaskets.
dunno.. but this year i'll be running .060 gaskets with my pre-clearanced pistons and hopefully a nice double roller timing set.
That's what i ment..Originally posted by SappySE107 View PostI just wanted to say, that shaving the heads .020 doesn't give you less clearance between the piston and head. its the valve clearance, which really shouldn't be a problem.
Swap to 3400 heads if you want compression.
Damn you Captn Morgan!
