Well as some of you know, I swapped in a cammed 3400 into my 94 Olds. I have the 1211 grind, p&p'ed intakes, and a 65mm TB, done to the motor. The problem Im having, is when coming to a stop, ( does not do this all the time ) it acts like its running out of gas and wants to stall but doesnt. The RPMS will drop from ~800rpm to ~300-400rpm and bounce back and forth. The other issue is that if your going down the road at lets say 30mph, give it half throttle, it barely goes anywhere, then all of a sudden takes off. Somestimes it doesnt even take off. the best way to describe it is as if you were pulling a trailer with a huge load, and punch it, vs punching it with no cargo at all. Whats odd is this started after I put the 65mm TB on. When the 56mm TB was on, I didnt have any problems at all. Also, sometimes it seems like it really just dies in the topend from about 80mph and on. Like somestimes itll hit 110mph FAST. Then other times it takes forever to hit 85mph. This weekend Im gonna try putting it back on to see what happens, but other than that what can I check? Fuel filter was just replaced, FPR is good, and pressure is good, fuel pump is good too.
Also, I have the data scans from everything, and it all looks good. LTFT is 127-128, STFT was 130 ( with a clogged fuel filter though ) BLM is 16 and my AFR at WOT was 12.4. At idle, spark is 15deg, but once you give it throttle, it jumps back to like 24 or 27 around there ( cant remember exactly what it was ) and I know the IPW at idle, but I havent check it at WOT. Theres no fault codes, nothing stored ot anything.
Thanks for any help guys!
And display it as a graph, number, or analog gauge. I have BLM, INT, MAP, TPS%, Speed, Tach, Temp, Trans temp, IAT, etc as analog on my dash on scannerpro.
