need pix of 3500 fuelrail/connectors
  • MidnightriderZ24
    replied
    returnless is usually ditched in turn for return style anyway.. the fuel recirculating back to the tank helps cool it.
  • onefastV6
    replied
    Originally posted by Driver_10 View Post
    Arent those the short, "stubby" ones?
    Yeah, the 3500 has the short stuby injectors. I think the 5.3L & 6.0L truck motors have them aswell.
  • WrathOfSocrus
    replied
    3900 however doesn't have an option to put the older stuff on, so for something like that you'd need to go to returnless..
    The only thing wrong with the rail is lack of an FPR and return. You can use an aftermarket FPR that has a return built in. I also believe someone here used an FPR off of some kind of fuel injected chevy big block. I'm sure several stock FPRs can be found at the junk yard and adapted to be put between the fuel line and fuel rail with just a few fittings. I don't think it's worth switching completely to the returnless system in a vehicle that has the return line unless you are swapping the entire drivetrain and electronics from a donor vehicle.
  • Driver_10
    replied
  • onefastV6
    replied
    Delphi Multec 2 if I remember correctly
  • Driver_10
    replied
    Really now... And what type of injectors do they use. Motronic, bosch?
  • onefastV6
    replied
    Are those rails stainless?
    Yes they are stainless.
  • Driver_10
    replied
  • hookdonspeed
    replied
    ty, ima have to do some research on whats needed to make it a returnless...
  • mcgavinz26
    replied
    Returnless is one less line to plumb (weight reduction, right?). I don't know how common the physical size of the 3500 injectors are, possibly harder to find aftermarkets in different flow ratings? Thats just speculation though. I have a bunch of other pics of my stock 3500 in that same folder.
    I have every intention of using the 3100/3400 return system in my build.
  • IsaacHayes
    replied
    Just swapping a 3100/3400 return style is the easy to use with existing stuff. 3900 however doesn't have an option to put the older stuff on, so for something like that you'd need to go to returnless.. Easier IMO to swap the 3100/3400 rail on and call it a day.
    replied
    I have a 3500 rail sitting around, i'll get pics tonight.
  • hookdonspeed
    replied
    yea, thats the returnless system, im debating on using that, or going to a return style..
  • mcgavinz26
    replied
    Aren't those returnless systems? So the regulator is at/in the fuel tank?
    If I remember I can take pics tonight when I get home. I'm doing some reorganizing and cleaning in the garage anyways.
  • hookdonspeed
    started a topic need pix of 3500 fuelrail/connectors
    anyone have some good pics of the 3500 fuelrail, fuelpressure regulator, and feed line connector?
