Originally posted by 3400-95-Modified
View Post
After learning a few things in this thread, I would understand why I should stick with the 195 t-stat. But having a turbo now it makes more sense to get a 180 and no lower, no 160* t-stat. I have a 180 t-stat atm.
Though now I will start to fine tune the coolant fans on/off to a higher heat range and judge the best spot to enforce.
My stock fans would come in stages, one before the other at diff temps. I think by narrowing the gap I can keep the coolant at a specific temp when being pushed. Sort of like having 180* coolant during normal driving but having a higher temp tuned in for the days I am running boost for fun.
So now the question I ponder is, what is the optimal coolant temp and oil temp for boost/performance operation. If higher temps increase efficiency then power output should be increased as well. Anyone have an idea? 220*, 200*? Then tuning the oil coolant to a specific temp I could run a bypass with adjustable valve to the oil cooler and adjust the valve to a desired flow to the cooler versus back to the pan. Basically increasing or decreasing oil temps with a valve.
Simplified, what is optimal temp for coolant and oil for performance?
