Newbie wanting to do 3400 (LA1) engine mods
  • Christos05
    replied
    I have a 3400 to and i want to reach minimum 200whp. But i'm stock with the headers... I need to build mine but how? i dont want to pay over 1000$ for this... How much can that cost to me?
  • robert 1980
    replied
    Like i said i live close to him and if he wanted to see my car i would take him for a spin.This way he could see what wot-tec parts could do for his car.
    I agree 100% on tuning i've seen a 3400/3500 hybrid go from 14.2 to a 13.6 Most mail tunes are generic i would talk to 3400 modified for help.
    If your keeping the car save and do it right
  • TGP37
    replied
    Originally posted by Fireball View Post
    Don't make enough power for bigger injectors to be required at this point.
    And if it was close, an AFPR would be cheaper. Boost the fuel pressure slightly.
    Originally posted by brigoyanks View Post
    well then the fender wall intake, 62mm tce, ported UIM and EGR delete should help me get to that 27+ mark
    A tune will make it all come together and SHINE. Anytime you change the dynamics, the tune needs to match it to get the most of it.
    I would say a mild sports cam and a tune.
  • brigoyanks
    replied
    obviously if i did a top swap or any build as through and insane as your i would get a real tune, but as for my daily driver it did its job which was mainly egr delete, and the exhaust codes, also he did some stuff with he trans shift points and rev limiters and stuff idk really what he did but i only got it for those two things.
    also he did something with 2nd gear, if i put the car in 2nd it stay in second always, so i can do 2nd gear starts if its snowy and i don't have a lot of traction, 2nd gear starts helps to not spin tires and get more stuck in the snow.
  • bob442
    replied
    mail order tune eh? those never blow up in someones face...
  • brigoyanks
    replied
    http://www.getoverkilled.ca/3400.html they also do tunes for 3500 and 3900s and 3100s
  • bob442
    replied
    headerz n dyno tune lol, BTW whats a Overkill PCM?
  • brigoyanks
    replied
    Originally posted by kflo 93 gt View Post
    A set of tubular headers is the next best bang for the buck. There is no debate in this situation. None.
    Stock 3400s have dynoed a 20hp gain just by adding headers. The stock manifolds are designed for packing the engine into the engine bay, not for performance; anything but, really.
    If you don't get deep into engines yet, don't worry about the top end swap. Put on the headers and enjoy.
    And as far as just adding horsepower numbers together - it doesn't work like that. I used to think it did, when I was your age...
    thanks alot! i you just changed my mind to not do a top swap
  • Fireball
    replied
    He's right!
    A better breathing engine will get better results from exhaust vs a stock one, etc etc..
    I don't understand myself, I just get to read a lot of things from the intelligent posters on this site
  • kflo 93 gt
    replied
  • robert 1980
    replied
    Yeah thats not far from me.Well either way you won't get much from it without a good tune.But yeah if you ever wanted to check the car out let me know.
  • brigoyanks
    replied
    like closer to 40 or 50hp gain? , i have a overkill pcm too, and egr delete
    so stock is 180
    then add 3500 swap and I'm around 200
    intake manifolds, tce TB, Cutsom CAI 215ish
    headerback exhaust, pcm, tstat, egr delete, poly mounts, 230ish
    idk this is just guestimates
  • Fireball
    replied
    I think with intake work, 3500 swap and headers you'll be well above 30 hp
  • brigoyanks
    replied
    Originally posted by robert 1980 View Post
    I didn't realize your from jersey too where about? To be truthful i dont see headers making 30 hp.
    I've heard on a 3.8 15 to 20 but i never did dyno my car.I didn't know a lot either be you learn quick.
    If you not to far you should check out my car sometime
    30 yes including the 3500 swap and intake work
    and i live in somerset county
  • robert 1980
    replied
