I am doing some research, and need some info:
1) For the 1999-2004 GrandAm, Alero, and similar GM models that use the same throttle body, which throttle bodies are the most popular upgrade, and do they use the same mounting bolt pattern?
2) If the mounting bolt pattern is different, I would need a pic file of the mounting flange or something I could print out to actual size from the computer, or if a vendor sells the gasket for them, I could probably just buy the gasket.
If they are no longer available I will just use a stock pattern with a 65 mm opening.
Thanks.
Thanks.
