Alright, some of you know of my Camaro, some don't.
Basically has a complete LX9, 65mm turbo, cam, yadda, yadda...
I want to know something, I plan on running this setup for a bit, but am always looking into the future.
Seems that the 3900V6, LZ9 engines are way down in price these days and would appear to be the next logical step for me...
What is different from an LZ9 to an LX9 ?
Correct me if I'm wrong here, but I'll need :
1. returnless fuel rail / system.
2. VVT disabled somehow. / gettin a cam anyways.
3. variable intake runner disabled / maybe make a new box plenum with LSX TB. (OR LZ4/LZE UIM works I read)
Questions :
-Is the crank to flexplate/flyweel the same distance / bolt pattern? I need to be able to use my current 3500 flexplate.
-Are the motor mount bosses the same on the block ?
-Do 3500 headers fit a 3900 ? same exh. flange ?
-Does a RWD timing cover / crank pulley setup bolt on as it did with the LX9 ?
I was going to pick up a motor and just find out everything myself, but if there are any MAJOR snags, I'd like to know now...
so far ^ if all these items check out, it wouldn't be THAT difficult of a swap, or am I missing something.
I actually tried searching a while, alot ofthe threads that likely have my answer are 30 pages long and the information is scattered all over the place.
Thanks !!
Questions :
Thanks !!
The 3900 is just a big 3500 with no aftermarket support. I wouldn't want it for a DD because the MPG sucks and for performance, all you can do is boost it. Mars will love that, but for me, I would rather boost something I can throw parts at to improve it, not just add fuel, and more boost. Maybe that will change, but I would bet money it won't.
