3400 Monte
  • 3400 Monte
    Will a 3400 from a '00 Monte bolt into a '95 GA the same as the original 3100? I noticed it had dog bone style upper mounts. Will that block accept N-body mounts?
    Dream As Though You\'ll Live Forever, Live As Though You\'ll Die Today
    don't use the dog bone mounts, and should have to swap the timing cover. i don't see why it wouldn't fit.
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
      it would fit, you will need a different upper intake to fit your stock EGR unless you upgrade to ODBII
      1995 Monte Carlo LS
      3400 SFI 60v6
        Or you could make an adapter plate and use your original one.
