Thought I share my results. Stock heads, no extra mods. Measured with water and a syringe. Sealed with glass plate with 1 little hole to prevent surface tension distortion of reading.
Volume (inc valves, plugs)
- Intake port volume: 98.2 mL
- Exhaust port volume: 65.5 mL
- Cylinder Head: 27 mL
(no gasket, no piston..just the head)
Other Stuff
- Exhaust port cross section: 1.35" square
equivalent to 1.3" ID
- Exhaust port circumference: 4.2"
- Distance from exh valve seal to port end: 3.4"
(includes the curve in path)
- Exhaust port exits 75 degrees from parallel of head (left/right axis), perpendicular (up/down axis)
- Valve and port "D" shape are rotated 10 degrees from center.
Other Stuff
