I was dealing with this issue on a reground stock cam regarding whether or not I would have to replace the pushrods since the base circle was reduced and the rocker arms non adjustable. Schneider Racing said that I shouldn't have a problem eventhough .040 was machined off the base circle. I have installed the cam and one pair of pushrods and I do have some preload on the lifter, but since that was with the engine upside down on the stand due to buttoning up the bottom end at the time, I haven't really checked to see how much preload. I believe at least .020 is required. I would still prefer to have the original specs in place. They also said that I would not loose any power from the reduced preload.
iron head pistons in a 3400 w/cam
wtf? that's alot of preload lost if the stock pushrods are used... I wonder why nobody's ever said anything before???Originally posted by SappySE107 View PostThere is almost .090 off the MMS stage 2 cam.
note to self: don't buy from ARI.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
that still dosen't seem right.. maybe for a regrind but for an aftermarket cam the base circle should still be the same. I've never had to use special pushrods in any engine i've built (most were SBC's)Originally posted by SappySE107 View PostTurns out its .070 but this is a stage 1 cam in a stage 2 box. Looks like cammotion has scrwed up again. Stock base lobe is 1.290" and the stage 1 cam I have is 1.221"
I've had cams that were so big that you had to flop them side to side forever to get them to slide in...
that sucks about the cam tho, i bet you could sell it easy
Small block chevys and other engines with adjustable rocker arms don't count, it's the non adjustable rocker on the aluminum heads that's causing the fuss, so if the base circle on the replacement cam is less than stock you have to be mindful of the preload.Originally posted by Superdave View Postthat still dosen't seem right.. maybe for a regrind but for an aftermarket cam the base circle should still be the same. I've never had to use special pushrods in any engine i've built (most were SBC's)
Haha, that was probably my stage 1, since I got the stage 2 in a stage 1 boxOriginally posted by SappySE107 View PostTurns out its .070 but this is a stage 1 cam in a stage 2 box.
It doesn't make sense that Milzy would sell a cam that requires custom pushrods but not have any mention of that or have pushrods available...Last edited by moonwell; 10-03-2006, 12:21 PM.
