could a 90 3.1 ecm run a lq1?
    replied
    because you can't tune the 94-95 3100 PCMs? at least not the MAP based ones...
  • no_doz
    replied
    why are you using that pcm?
    replied
    Originally posted by no_doz View Post
    that is great to know robert, so i assume you swapped from 3.4 to 3.1? & if so were the engine mounts much different? i realize the surface that connects to the engine probably were a good deal different, but what im wondering is will the grand prix engine mounts work in the lumina?
    ummm, what? i've always had a 3100, just now i'm using the 3.4DOHC PCM to run/tune it... isaac probably mentioned it to point out that the timing setups were completely compatible...
  • no_doz
    replied
    replied
    exactly...
  • no_doz
    replied
    yea hes going to use the tgp code-so the crank sensor will be the same?
    replied
    Robert is running his 3100 on TDC code, so they will work you just gotta tune for the specifics of the motor of course.
    TRUE.
    no_doz, if you are going to run it with TGP code, i can probably get you a starter bin made up using the fuel and spark tables from a DF BIN and "transplant" them into TGP code(8D or 8F, i can never remember). i can't guarantee the boosted values will be right, but the vacuum cells should be accurate enough.
    and X2 on the crank sensor, its the same 3X sensor between the 3.4 and 3.1/3x00s...
    if you're planning on using code59..... i really can't help there, i don't have any experience with it.
  • IsaacHayes
    replied
    3.1mpfi and TDC 3.4 are going to use the same setup for crank trigger. You'll just have to tune it for the VE of the TDC and spark tables and all that. I'm guessing he is going to use the TGP code to run it since it's boost?
  • no_doz
    started a topic could a 90 3.1 ecm run a lq1?
    im -considering- swapping the grand prix gtp's engine into my lumina for my supercharger build, & the guy whos gonna program my ecm for boost can only do so for the prom thats in it, now from what ive heard as long as the crank sensor setup is done properly, these engines dont care what ecm they are hooked to (relatively), is this correct?
    if so what would i need to make the computer know when to pulse fuel (im assuming an external crank sensor?) if so what x crank sensor will i need (i dont know much as far as crank sensors go)?
