got a powrtuner!
  • ericjon262
    replied
    normally closed, open when pushed. Thanks robertisaar!
  • ericjon262
    replied
    Originally posted by ga2001532 View Post
    I haven't checked what it wants yet but looking at the design of the clutch cruise switch it has to be normally closed. So am thinking that it is open right now disabling the cruise. Tomorrow I think am taking out my motor so I should find time to figure this cruise out
    there are a couple of different clutch switches, so it may be either way.
  • ga2001532
    replied
  • ericjon262
    replied
    I think the clutch switch input is pin 18 on the clear connector. still trying to find a diagram showing whether it looks for ground or open (probably ground)
    replied
    Why do you need both?
  • onefastV6
    replied
    My powrtuner arrived today, which will be used in conjunction with my HPT package.
    Sad that I need both to do what I want to do.
    replied
    The computer must of switched what it wants to look for because I never had to bother with those switches it just didn't disengage it. But the cruise worked.
    That's what I was thinking, is it was looking for a different type of signal now somehow... The only signals the ECU sees though from the Cruise unit is the Cruise status... at least that's all I can see from the diagram.
    Following the diagram though, the shift interlock arrow (looking at how that's wired)it just goes to the brake switch again on the same pin which connects to the same fuse, so I think what it's saying is the brake switch is just used for the shift interlock as well as cruise disable... SO that would mean on an Auto it only has brake input to disengage where the Manual has both brake and clutch and if you ask me that wouldn't be changing any signal going to the cruise system.
    Test something for me... Check Pin B (Purple or brown wire one, not white, There appears to be two switches, One for this function and one for the brake lights or "brake applied switch") on the brake switch and tell me if it's hot with the brake on or off... The only difference I see in this diagram is the "shift interlock" diagram shows the brake switch as normally open, and the M/T cruise diagram shows the brake switch as Normally closed... I wonder...
    1996-ShiftInterlock.pdf
  • ga2001532
    replied
    Well I believe their is a cruise disengage switch and a clutch in switch. I don't have either. Unless the cruise switch is closed till I hit the clutch pedal. I bet I just need to find the pinout for the cruise switch and jump them together. I know to tap the brake or shut it off before pushing clutch in. Unneeded frustration to wire them up.
    replied
    I wonder if the PCM is looking for a clutch signal to turn on CC? I know the CC module looks for one.
    That is possible, but you'd have to find a car that has that cruse module and a manual option to see what the CC unit wants to see... I attached the 1996 diagram for a Beretta CC unit, not sure if they are the same unit or not.
    1996-electronic-Cruise.pdf
    Going by that the Disengage input just goes to a second switch that appears to be on the clutch, vs the shift interlock system which he said is removed on his. Other than that I don't see any other at vs mt differences in wiring.
  • ericjon262
    replied
    Well according to him it is broken... He has no cruse when its in manual mode... There has to be something that triggers that. I'll have to dig through the bins later, might require a pin change or something but I don't know.
    replied
  • TGP37
    replied
    It drives totally normal now I think. No matter how fast am driving throw it in neutral and it idles. That one setting made everything go away and act like it should but just no cruise everything should be off or maxed
    Ehh, don't fix what isn't broken, lol.
    I am glad you were able to fix your issue.
  • ga2001532
    replied
  • TGP37
    replied
    Never thought about all those, I noticed one problem my cruise don't work in manual mode
    Try setting all your shift points to the max allowed and turn off all torque control.
    I imagine you might of had the PCM pulling timing during what it thinks is a shift event. Other wise, setting the vehicle to be in P/N might make a difference as well, as Eric was saying. The PCM has different settings for accel enrichment in both P/N or D.
    Another one might be the throttle follower settings. Adjusting those for a manual swap isn't unheard of. Changes the way the IAC acts between shifts, which an auto PCM would think is throttle off and might engage DFCO.
  • ga2001532
    replied
