Originally posted by shapeshaver
View Post
LX9 RWD Swap - timing cover and pump specifics
Stock alternator for a 3.1 Cavalier, water pump pulley was either a 2.8 Camaro or a 3.4, cant remember. Tensioner was pieced together with parts from mcmaster-carr.
Hey Dave, which alternator is that? I am trying to figure out where to source the right alternator and pulleys. What did your alternator come off of? And the water pump pulley? Tensioner?
I've found that only minimal belt contact on the water pump is necessary, but it doesn't hurt to have more either.
Sorry, I can't get on this site from home for some reason...
here was mine:
TCE alternator bracket, added an extra idler for better wrap on the water pump. Turnbuckle tensioner.
I can post pics of my belt routing later on.. worked great with only an alternator.
Guest repliedI haven't got to that project yet, but it's getting closer to the top of the list.Originally posted by Canyonero View PostWhat did you do for belt routing on this project you mentioned? I have an LX9 that I want to put in an Opel which also has manual steering, so the only accessory would be the alternator.
What did you do for belt routing on this project you mentioned? I have an LX9 that I want to put in an Opel which also has manual steering, so the only accessory would be the alternator.Originally posted by The_Raven View PostJust to add another option, this is how I laid out the belt routing on my Franken60, many years ago (over 10 now.
I'm trying to come up with a nice belt layout for my next project, there will not be any power steering, and I hate using extra idler pulleys, but would like a belt driven water pump.
I have a few ideas in mind, but nothing I'm overly happy with yet.
Guest repliedNo, I have an L28 that I added a turbo to. I plan to swap it out soon enough though.
Thanks for the photo. Do you have a GM V6 in a Z? My friend is doing a 260 right now and is supposed to be picking up an LS1 this coming week to go into it.
Guest repliedJust to add another option, this is how I laid out the belt routing on my Franken60, many years ago (over 10 now.
I have a few ideas in mind, but nothing I'm overly happy with yet.Last edited by Guest; 02-23-2013, 01:16 PM.
Thanks, that's exactly what I needed to know. Now if the crossmember guy would get back to me, then I can get a start on this.
I'm 99% sure that RWD timing covers won't bolt to the 3900. I don't think there are many parts that are interchangeable between the VVT engines and the non-VVT engines
It looks like it will fit but will be VERY tight. Do you happen to know if the 3900 is the same block as the 3500 and if the 3.4 front motor cover and water pump will work on it?
