abs light did I mess up
  • BLADE
    • Mar 2010
    • 78
    well the abs light/air bag light used to only come on here and there after I pulled the master cylinder off the car. but now its on steady. I dont hear the normal abs clicking anymore after startup. Could air in the system cause the check balls [clicking noise] to not work. I bleed the system at all the wheels [right rear,left rear,right front,left front] and then the two bleeders on top of the master cylinder. Have I bleed in the wrong order. It will stop good.If I need a code reader where would be a good place to find a abs code reader that will fit a 95 chev berretta v-6 3100 with absIV.registration is about due need to figure it out quick thanks guys
