94 GTP Transmission troubles!!
  • fleetwoodguy79
    • Nov 2004
    • 1
    I'll try to explain this as best as I can!
    I dont know if its slipping, or not having enough vacuum pressure. First to second normally shifts fine, but when it tries to go into third, its like it shifts into neutral unless you give it some throttle then it will START to shift. Sometimes you can hear this grinding noise when its shifting into gear, VERY strange. 3rd to 4th is perfect and the tq. converter locks up after that just as it should!
    Is it a vaccuum related problem?? Or is my trans about to die?? Any help would be greatly appreciated guys! Thanks!
