before I lose my hand/ ac removal
  • vsop4me3.1
    • 482
    I need to remove the component shown in the 1st pic, but in the chiltons book it say that the book does not cover the ac removal due to chance of serious injury or death. I figure it's becuase the4 system is under pressure. My questions are:
    1. can I just remove the copper ring and frame mount bolt in pic 1 and remove the bolt in pic 2 and its out?
    2. do I need to remove pressure for the system?
    3. the pipe that has the copper ring, does that run into the firewall and can I just remove it at the firewall?
    thanks
    Matt
    I wish 10% of the people on the road knew how to drive
  • Juglenaut
    • Dec 2003
    • 1130
    RE: before I lose my hand/ ac removal
    If you remove the nut, freon on oil charge will spew like a drunken bastid.
    I may want to suit up with a good set of goggles and a mask to cover your mouth, even a good full cover plastic hood like you see in the movies would be good. Or just do it and run to let the pressure slowly release.
    In other words it is recommended to have a mech release and capture the freon and oil charge.
    I am back
    Mechanical/Service Technican
    • vsop4me3.1
      • 482
      okay, thanks for your help.
      • SS_EURO
        • May 2005
        • 74
        I've removed my a/c comp. and the new belt doesn't ride the w/p as much as I would like it too. As I'm sure you guy s would know what kinda of idler pulley should i be looking for?Is there one that is preffered or will any one that'll fit be good?
        I\'d rather push a CHEVY than drive a Ford!
        • sharkey
          • Jun 2004
          • 2061
          get the factory pully off a 2.8 or 3.1l without a/c. its the proper setup.
          as for just cracking the line and letting the feon out, its not only dangerious, bad for the enviroment, but its also illegal. take your car to a shop that does a/c stuff (dealership, rad shop, ect) and have them drain it. itll cost a bit, but your not gonna make a mess or hurt yourself.
          • vsop4me3.1
            • 482
            I had a shop drain it for free, It only took like 5 minutes. I removed the component in the pics above, but I still need to remove the piping connected to the radiator and the one leading to the firewall. I left the pulley part, cuz it's not in the way and it's needed for the belt.
            • SS_EURO
              • May 2005
              • 74
              I pulled the compressor out on mine you just need a belt without a/c and an Idler pully there is a boss in the timing cover for it. Thanks for the info
              • torq455
                If I only had money!!!
                • Dec 2003
                • 1615
                there is a valve core in the low side charge port. just loosen that and wait. mine was leaking, so i used the fine needle nose pliers and got it tight.
                Andy
                fastest 1/8: 10.19@ 67.17
                fastest 1/4: 16.16@ 82.70
