Originally posted by betterthanyou
View Post
Readings of 205 to 275 kPa (30 to 40 psi) may be considered normal during moderate road speeds of 55 to 60 km/h (35 to 40 mph) with the engine at proper operating temperature. If equipped with the optional LB6 engine (engine Code W), the oil pressure reading could be extend an additional 10 psi (70 kPa) higher under the same operating conditions described above.
But again, the OEM pump had its spring set at 70 psi (Code W: LB6)...but this Milling Oil Pump blows at 60 psi. Hence, unless an OEM pump was installed...who knows to be exact on readings.
