MAP Sensor Wiring
  • Fireball
    • Sep 2010
    • 128
    MAP Sensor Wiring
    Hello,
    Is there a harness (extension or conversion to 3500 style harness) for the MAP sensor?
    I used splices last time and it eventually ended up causing electrical havoc... is there a plug and play solution for this??
    I know the J-Body one from the 2200 uses the same style but I'd still need the harness extended as well...
    Thank you,
    Mike
